Originally Posted by bados
It seems like there are a lot of problems initially with this
Where did you hear about problems with the Stage 1? In the newer models it's just a matter of swapping out the computer. The older ones require a change of fuel injectors. If your not mechanically inclined, yes, have the dealer or an outside mechanic do it for you (probably cheaper). You need your VIN number to order the Stage 1 so it's made for your engine. There shouldn't be any problems.
When owners start adding, all the other items to squeeze out more hp, then problems might arise.
P.S. Actually, the VIN has nothing to do with having the Stage 1 made for your engine. Chrysler (or whoever owns it now) just want to keep a record of who has it. Heck, now that there is new owners, maybe you won't need to supply your VIN.
