Originally Posted by Mean Green
Don't new injectors come with the Hahn kit? If not I'd ask Hahn Racecraft. If you have a downpipe for a SRT-4 it won't fit a PT because it'll be a few inches short. You'll have to add to the midpipe. Depending on how much boost you want to run you may need more fuel and I'd want a wideband A/F gauge. Wouldn't want to go lean and blow up the motor.
I purchased the turbo kit which didnt involve no fuel system, that is why I was thinking about the stage 1 kit. Also I know for a fact that Ill need a wideband since thats the main gauge I use to live off of(ex-rotary owner
) anyways, Im plannin to boost up 2 15psi the max. As for the downpipe your right, but then again my exhasut is custom so it didnt matter.SO now that I broke it down to what goals I have in mind, do you think those injectors be able to stand up to those boost levels/turbocharger size?
