Old 27 Jun 2007, 09:35 am
Premiere Premiere is offline
Default Replace Multifunction Switch w/fog lamps
Old Part# - 04671594AD (2001 PT)
New Part# - 05073049AB (dated 6/2/07)
Cost to purchase at dealer - $63.45 plus tax
Install time - 30 minutes or less
Tools: Phillips screwdriver, small flat screwdriver, T10 torx
Remove negative battery cable
Move steering column to lowest tilt setting
Remove (2) phillips screws from underside of covering
Remove covering top and bottom and set aside
Remove (2) phillips screws on top inside
Remove (2) torx screws on right side
Pull wiper switch section out of your way to the right
Take small flat screwwdriver and pry out red locking tab on wiring harness
Pull out harness
Pull out old multifunction switch
Transfer foam dust circle to new switch (over lever)
Transfer flasher module (not included with new part)
Place multifunction switch back onto column
Install wiper section with the (2) small torx that were removed
Install (2) upper phillips screws
Install upper and lower plastic
Install (2) lower phillips screws
Connect battery and test.
Relatively simple install. Small red lock tab on harness is the most challenging part as the harness is in an awkward position. Nice to have headlights back or to be able to turn off your fog lamps.
Happy PT motoring
KG in Michigan
