Old 25 Aug 2003, 05:52 pm
Chipmunk Chipmunk is offline
Default Turbo Timer How-To Wire Guide (Blitz FATT)
Thought I would post these pics I made For Wiring the Blitz FATT 2 Turbo Timer.
First off, here is the wiring schematic from ther Service manual for the Ignition Harness connector. We need to tap the 1,2,3 wires.
A picture of the Wires that need to be tapped. And the corresponding colors for the Blitz Harness.
A picture of the Blitz harness tapped into the wires.
A picture of the Connector back in place and the Blitz harness zip tied out of the way of anything. Also make sure the wires have enough slack so that the steering column can move up and down.
Connect the 2 grounds and purple wire to a good ground. In this case I used a fuse box screw.
Now all you have to do is figure out where you want to put the control module.
Hope this will help you out!
Enjoy!
-=Matt=-
