Old 09 Jul 2007, 09:24 pm
triggerman triggerman is offline
Default Finally Found the Receipt!
After some searching thru my files I found the invoice for the "crazy door locks". I had this fixed on my 2003 PT in Jan 0f 2004. I haven't had the problem since they fixed it.
The invoice says:
Perform DRBIII Check fault code found drive door switch failure. Perform ohms test from drive door lock cylinder switch to RKE module. Found lock cylinder switch short out.
when all is said and done..
more is usually said than done!
