Originally Posted by jayguliano
I just finished installing a pair of HID light kits in my 06 GT. My first attempt was without a relay kit and they worked just great with the engine off but would not power up with the engine running. I suppose there is something with the controler that drops the voltage under load if it sees too much amperage to the headlamps. At any rate installing a seperate low beam relay to power the HIDs directly off the battery solved the issue. The problem is now aiming the lamps. I had to bring them up and used a T20 driver to turn the outside screw to raise the beam but now I want to aim the drivers side out slightly since it is aimed too much toward center. The inner adjustment holes do not look like they have an adjustment screw inside them and I can not feel one with the T20 driver. What am I missing?
Hi,
I'm from NeverBurnOut, a site sponsor -- do you have DRLs activated? If so, disable them. If not, don't fire up your headlights until you've turned your engine on. Let us know how that goes.
Daniel
NBO
