Well. Once you start them spinning, you can spin them thru redline, bounce off the rev limiter, grab second gear and drive to the tire store for a new set of tires. On the easy side, if you dump the clutch at about 3 grand, they will spin for a long while, then you can get a good solid chirp when you grap second gear.
Mike
