Old 30 Jul 2007, 01:56 pm
CREWZIN CREWZIN is online now
Default Re: Changing the battery
Originally Posted by comPuTer View Post
It is my understanding that the battery in the Cruiser is in the same location and would require the same work. Is that correct?
No. It's located in the front of the engine compartment on the drivers side. If you read my post above, there are about 4 easy steps to get at the battery. Un-clip and take out the front part of the air box. You can then see the battery, and if I remember right (it's been years) there a heat blanket around the battery held on with a strap. Take the strap and heat blanket off. Then the hold down for the battery and the positive and negative cables come off.
