Originally Posted by JCsGTPT
K&N drop in air filter, part # 33-2153. Should be around $30 or so. If you have Autozones in your area they carry it. This is a reuseable filter so don't forget what is called the Recharging kit for $10-15. I haven't checked the mileage interval yet but every so often you have to clean it and re-oil it.
Also, many do what's called the air box modification to improve the airflow even more. I have done it and it is very simple and takes less than an hour even for a novice. It entails removing a white ring silencer and cutting back the snorkel that feeds into the airbox. If interested, you can search on it in the forums for more detailed instruction.
JC, thanks for the info. I had a guy tell me that if I put on a dual exaust it would help a lot, have you heard of any such thing?
AJ
