Old 04 Aug 2007, 02:17 pm
CREWZIN CREWZIN is offline
Default Re: Better MPG for a 2005 Crusier
I posted this before to another owner that was loking for better mieage, maybe it will help here.
The PT isn't known for it's mileage. The faster you go the worse it gets. Aerodynamically it's a brick. Load of little things you can do to increase the mileage. Go about 3-4 pounds of air above the recommended pressure in your tires. Switch to synthetic oil. Take off from stoplights gently and slowly (but not slow enough to piss people off) get up to the speed limit. Don't run up to stoplights, look ahead and take your lead foot off the accelerator when you see a red light coming up. Don't carry loads that you don't need (like golf clubs all week long when you only golf on Sundays). If nobody else gets in your car, take out the back seats. Go on a diet. ...only kidding. Every little bit helps.
