Re: Adding a trailer hitch to a 2007 PT?
Thanks for the info Triggerman. I need to have the hitch by this Friday so I finally found a local place that was reasonable and did work. The hitch and installation came to $210. The OEM hitch from Chrysler was $173.00 and then about another $125 in labour for installation. The odd thing is that the OEM hitch from Chrysler is only rated for a tongue rate of 100 lbs. and the towing capacity of 1000 Lbs., while the majority of the other hitches I found for the Cruiser were rated with a 200 Lbs. tongue rate and 2000 Lbs. towing capacity.
