Re: 2003 Error codes
Shaz,
Sounds like your overseas as we don't have the engine in the U.S. but the lights should work the same. First take all the toys from under the seats that were stuffed in there. See if you can figure out how to take the small black air filter box in the engine compartment out to gain access to the battery. If you can, take off the cable from the negative side of the battery. Leave it off for 5 minutes and re-attach it. Hopefully the air-bag light will be off, it works for the engine codes.
2000 PT. 95K miles, Original Owner
