  #12 (permalink)
Old 15 Aug 2007, 09:35 am
wait4me6920 wait4me6920 is offline
Default Re: Stage 1: Cost from Chrysler Parts & Install
Originally Posted by SR-PT4 View Post
I have an '04 Limited Platinum Series and I added Stage 1 when the car had 2000 miles on it. It now has 28,000 and has made countless trips down the dragstrip (best time of 14.4 @ 95mph) and it's driven fairly hard on the street too. Not a hint of trouble out of the tranny, although I did my dealer do a full flush and filter change at 24,000 miles, which is earlier than recommended. When I'm driving in town and know my speed won't be exceeding 55mph I keep the gear selector down in 3, not D. I don't kick it into D until I'm on the freeway.
There is a lot of discussion on various PT forums about how the auto tranny WILL fail in these cars, and it simply is not true - they don't ALL fail. Yes, the failure rate is higher than average, but as a percentage of total auto PTs on the road the number is low. Without a doubt though, it's the overdrive that gets eaten by too much boost, so things like boost controllers are probably not a good idea as they are prone to part throttle overboost, and that is not good for the tranny. And in case you aren't aware, there is only one autotranny across the entire PT range, from Base to GT. The only difference is the Autostick programming used only in the GT. The tranny internals are the same.
I think that adding Stage 1 was the best thing I've done to my car and could never go back to factory stock Turbo Lite status.
Amen! I have a '05 Ltd with automatic. At about 2500 miles added S1, & thus far at 28,800 miles no problems. I had heard of transmission failures, so try to avoid leaning on it too hard when in OD. I'd go for it - it makes night & day difference so far as response & overall performance is concerned.
2005 Turbo Lite, Stage 1, Mopar/Borla cat-back exhaust, Eibach swaybars, Bilstein coilovers, 18/8 TSW Montage wheels with 225/40/18 Exclaim UHPs, LED taillights, K & N drop-in & a few other goodies...
