Old 15 Aug 2007, 02:12 pm
Default Re: PT idles low and seems like it's going to die with AC on
There's an IAC (I think it's Idle Air Controller) servo that should up the rpms when A/C is turned on - sounds like that's your problem. Does the A/C work okay? Reason I ask is why would mechanic look at the A/C when your problem is the idle?
