Re: A/C not working
quick troubleshoot:
hood up, engine running, have helper turn AC on: Does compressor engage and idle jump?
Y/N
if N: check fuses for AC.
if Y:
Compressor is running... 2 AC hoses run to the firewall... one hot, one cold.
Is the cold hose getting cold?
if N: Compressor/condensor fault?
If Y:
try twiddling the interior knobs: turn off 'recirculate'?
try DEFROST or HEAT to see if you get cold air.
Also: check for blocked cowl intake/clogged filter?
AND: make sure HEATER HOSES are cool. if heater valve stuck open will negate the chill of the AC.
