Thread: Cruise Control
Old 23 Aug 2007, 06:11 pm
Netwizard1001 Netwizard1001 is offline
Default Re: Cruise Control
Originally Posted by SuGamer View Post
Sorry man, it's not that easy. If, and I mean if, the wiring IS there for the cruise control, you'll have to remove the airbag to add the cruise control stalk. But the biggest problem is the PCM. The cruise control is controlled by the PCM, and it would have to be reprogrammed for the new system. Definately not a do it yourself project, and the dealer will charge you close to 1k for it. Sorry to break your bubble. I inquired about it when I had my 2001 touring edition with no cruise control.
I installed a factory cruise control system in my base 2003 Pt Cruiser and it was a snap. The airbag is not hard to remove at all, a couple screws and two clips give you full access to it. My PT was already Pre-wired for Cruise Control and so I purchased a factory kit off of EBAY for $180 and had it in and working in 4 hours. The PCM didn't need to be touched at all!!! I would rate this as a definite do it yourself project. Total cost for adding factory cruise control $180.
