Re: Boiling water sound under the hood dirvers side
it happend again, so i turned on the A/C temp dropped fast, no problem the temp just made it a bit over de middle mark.
The Rad fan is ok, cause when i got the A/C on temp dropped at once, it has to me a stuck thermostat.
The other thing is that is was low on coolant again i added a lot almost a gallon, there seems to be no apparent leaks, at least i see no dripping, maybe its a small leak not noticeable, that gets evaporated. Now that the coolant level is full, i will track it every week to see it its keeps loosing.
Any suggestions
Another thing, i get the MIL on, when i turn the key to ON, positon, but nothing while driving, i did the error code check and nothing shows up, is this normal
