Turbo oil return line leak
I noticed while under the car installing another oil pressure sending unit (#2) that there was a leak around the turbo oil return line fitting. I checked to insure that the 8mm bolts were tight, and they were. I don't want to remove the line until I have the right gasket or seal. Has any one else had this happen? Was the gasket special (composite w/copper seal) or just high temp gasket material?
