Re: The Trunk Problem Thing
Hi Bijou,
Had the same problem with the wife's 2005 PT a week ago which prompted me to join this forum. Did not find anyone with the same problem until now. Noticed when starting the car the rear hatch would release. It progressed after two days to releasing when moving the shifter into drive and even when using the key to open the door instead of using the remote. It also released when pushing the power door lock switch on the door. I cured all problems when I pulled the fuse to the RKEM (#3). I started the car and and then tried to unlock the doors. Found I can't release the locks using the power door lock switch(must be tied into the RKEM) and had to manually pull up on the lock. Anyway...to cut to the chase...when I put the fuse back in everything was back to working as normal. Been a week so far with no problem. Since the RKEM is a programmable unit I figure the programming was corrupted and pulling the fuse rebooted it. Hope this helps.
