Old 10 Sep 2007, 08:15 pm
littleblueGT littleblueGT is offline
Default Re: 2003 MT High Idle
Do you have the plastic intake manifold? I had one that split at the seams causing a vacuum/boost leak. I found the leak by using bubble leak tester which is just a soapy solution with a fuzz ball applicator. Just apply around the seams and rev the engine, if you have a leak you will see bubbles.Did you reset the computer?
