Re: Free Pt Repair Manual for all
Rhamlin1,
According to the Haynes Manual, it's pretty easy to replace the Power Steering Fluid Pressure Switch (PSPS)
1. Disconnect the negative battery terminal.
2. Raise the vehicle.
3. Disconnect the elcetrical connection from the power steering switch.
(You'll find the PSPS on the backside of the power steering assembly. To unplug the eclectrical connection, pry up on the locking tab to release it.)
4. Using a deep socket and an extension, unscrew and remove the PSPS.
5. Seal the threads of the new switch with teflon tape.
6. Installation is the reverse of removal. Be sure to tighten the switch securely.
2000 PT. 95K miles, Original Owner
