Originally Posted by matt87951
This isn't exactly on topic - but close, so bare with me...
2003 Stage 1 requires injectors, while all other years do not require injectors. Did, starting in 2004 put in the higher PSI injectors in the cars straight from the factory? Or why all of a sudden, did the cars stop needing as much fuel with the addition of Stage 1?
I think this has been beaten to death - but will they ever make the Stage 2 for the PT, or has it been 100% decided it will never happen? Has anyone found an upgrade path similar to what Stage 2 would be? Just doing a little research before I make a decision one way or another on the PT GT 'Vert I am looking at buying.
Thanks!
Matt
From '04 on PT turbos came with Stage 1 injectors.
You will never see a Stage 2.
My '03 GT was modified beyond Stage 2 numbers.
As Brian said you will learn everything you need to know at PT Crew.
