  #13 (permalink)
Old 30 Sep 2007, 04:24 pm
csd csd is offline
Default Re: Boiling water sound under the hood drivers side
After checking all this.
It was weird now , after i fully filled up the coolant , the gallon , i put in there, there has been no leaks, no over heatings, nothing, works perfectly, but, i have stumbled into another problem, i was running like normally do, then parked and stayed in the car talking to a friend, then it started getting hot inside, the temp read 111 F,i turned on the car and the temp was in the middle, we had been sitting in there almost 1 hr, temp never went up but sat in the middle. after a few hrs. it cooled down completely.
So my guess would be that the low speed is dead in the fan or something that is not turning it on.I checked the high speed runs perfect.
I had the pt for short time, but should the low speed go on when you turn off the car?
Other thing i can't get the error codes, seems impossible with the key sequence, is there a range of time where the sequence has to be done?
