Old 01 Oct 2007, 07:27 am
Default Re: Anyone replaced the lock knobs?
You may get rattling with the ones you show - looks like their bases are smaller diameter than stock. If they are, go to home depot, etc, and get electrical grommets - get an assortment, but I think it's 3/8" you want, and fit them into the holes for the lock pins. If the rubber grabs too much, hit the pins with a shot of silicone spray.
Also - I found on both my '02 and '05 I had to use pliers to loosen the original lock pins - once started, I could unscrew the rest by hand.
