Re: Engine Shut Off, Will Not Restart
Doesn't sound like battery to me, since you can crank it, & lights, etc, work. Can't hurt to check battery connections.
Don't rule out the ignition switch - I saw a thread where that's what the problem was for symptoms roughly the same as yours - try holding/pushing in on key & see if that makes a difference.
Try doing a search here on ignition...
