  #30 (permalink)
Old 11 Oct 2007, 12:45 am
Windancer's Avatar
Windancer Windancer is offline
Default Re: want to upgrade my facotry rims
Originally Posted by Johnboy1975 View Post
So if you have 15's then you could buy these 2005 Chrysler PT Cruiser Custom Chrome Wheels (4) and just toss your stock tires on them. I am not too sure you should lower it just running 15's though because my PT has 16's and I was scraping like crazy while I was lowered. You could however buy the leveling kit,it would look good then.
Now if you bought these rims, as John Boy pointed out you could just put your tires on these rims although the rims may be a little wide for your 195/65/R15 tires seeing as they are 15x7. IMO probably the best tire to put on them would be a 225/55/R15 because it is the same diameter as your stock ones. But....you can go larger if you want but bear in mind it will change your speedo...so it would have to be recalibrated.
Does this make any sense to you? It's a bit of a complicated process. You have to decide the look you want. Do you want larger rims (17" or 18") with smaller sidewall tires or do you want smaller rims (15" or 16") with a little more sidewall or tire showing when looking at it from the side.
They probably aren't what you want but I have the original tires and wheels from my car for sale they are 205/55/R16 Goodyears on 16 x 6.5 Aluminum wheels. My car is a '05 Touring Edition 'Vert and I took them off my car at 3000 miles.
Terry
2005 PT Cruiser Convertible - Touring Edition
Mopar Spoiler, Mopar Ground Effects Kit,
16x7 American Eagle Chrome 5 Spoke Wheels
Toyo Proxes 4 225/50/R16 High Performance Tires
