Old 12 Oct 2007, 07:31 pm
slartyblarfast slartyblarfast is offline
Default Re: P0601 error replacement parts
P0601 is PCM internal fault. This is the PCM saying dont bother to do any diagnostic. I am bad and therefore need to be replaced. The part number you have is for a remanufactured PCM hence the R in front of the number. If you are under 8 years and 80,000 miles you can get it replaced at the dealership under emissions warranty. If not then you will still have to deal with a dealership because the PCM will have to be programmed to the car. It will have to have the VIN and SKIM codes burn into it.
