Thread: Engine Issues
Old 13 Oct 2007, 09:11 am
daveinozbikes daveinozbikes is offline
Default Re: Engine Issues
You stated that after you replaced the plugs and wires the problem went away for a while. I reckon your Champions are fouling or failing. Try NGK...they"re the best in my opinion. Years ago I tried Champions in a Merc. The engine would not run. Tried a different set..same problem. Won"t cost much to try anyhow ?? Won"t hurt to mix some injector cleaner with the fuel...don"t expect quick results though.
