Re: Need help asap...
P0325 OBD-II Trouble Code
Technical Description
Knock Sensor Circuit Malfunction
What does that mean?
A knock sensor tells the engine computer when one or more of your engine's cylinders are "knocking", that is, exploding the air/fuel mixture in a way that delivers less power and can be damaging to the engine if prolonged. The computer uses this information to tune the engine so that it doesn't knock. If your knock sensor wasn't operating properly, so that it was always indicating a knock, the engine computer's response may have been to change the ignition timing on your engine. The knock sensor generally threads into the engine block. This P0325 code may show up intermittently or the Service Engine light may be lit constantly.
Symptoms
You may notice drivability problems including a lack of power and perhaps some hesitation. There may also be other symptoms.
Causes
A code P0325 most likely means one or more of the following has happened:
* The knock sensor is faulty and needs to be replaced
* There is a wiring short/fault in the knock sensor circuit
Possible Solutions
* Check the resistance of the knock sensor (compare it to factory specs)
* Check for broken/frayed wires leading to the sensor
* Replace the knock sensor
P0340 OBD-II Trouble Code
Camshaft Position Sensor Circuit Malfunction
This indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
Symptoms
Symptoms can include:
* Hard starting or no start
* Rough running / misfiring
* Loss of engine power
Causes
A code P0340 could mean one or more of the following has happened:
* a wire or connector in the circuit could be grounded/shorted/broken
* the camshaft position sensor may have failed
* the PCM may have failed
* there exists an open circuit
* the crankshaft position sensor may have failed
Possible Solutions
With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
* Visually inspect all the wiring and connectors in the circuit
* Check for continuity in the circuit wiring
* Check the operation (voltage) of the camshaft position sensor
* Replace the camshaft position sensor as required
* Check the crankshaft position circuit as well
* Replace circuit wiring and/or connectors as required
* Diagnose/replace the PCM as required
2000 PT. 95K miles, Original Owner
