Old 13 Oct 2007, 09:22 pm
2003gt 2003gt is offline
Default Re: Need help asap...
The car was into one dealer had it put on the diagnostic test and they went right through the wiring and said nothing was wrong they replaced the 2 sensors and could not get the error to stay cleared. It ran like a peice of garbage bucking and everything. They said the computer had to be reflashed as it is giving false error codes and the one they had was broken so to take it to the other dealer down the road. I drove straight there (5 min) and they said they had to do there own diagnostic test. They again said they could do nothing without changing the crank and camshaft position sensors. So they did,now this is both sensors changed twice and both times if I didn't change them they would not service the car because until they changed the sensors they would consider the sensors the problem. Now that's 4 sensors in 1 hour ($700) then they reflashed the computer. Needless to say I was going nuts with them. The sensors and flashing are the only things not covered under warranty...of course. They reflashed the computer and everything was fine for almost 2 months. Now today the car runs perfect but suddenly the oil light came on and wouldn't you know it the code 325 again. The sensor is not our problem, I can definitely rule that one out, the wiring a gargage just went through so that is not the problem, the oil level is perfect. There's something else going on here.
