Old 23 Oct 2007, 07:12 pm
Mean Green Mean Green is offline
Default Re: are there any vacuum/pressure tubes that can be disconected to trick obd computer
If you want to trick the computer into higher boost then get a boost gauge, a wideband air/fuel gauge and a mapclamp. You just can't go to higher boost without knowing the air and fuel mixture. Run too lean and you'll destroy your engine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
