Old 24 Oct 2007, 10:36 am
03electricbluegt 03electricbluegt is offline
Default Re: are there any vacuum/pressure tubes that can be disconected to trick obd computer
Putting a manual boost controller will allow you to run more boost up to a point. I ran an MBC at 15psi on my car with stage 0. I threw an overboost code one time while at wide open throttle getting on the interstate. I hated the part throttle overboost so I removed it. Stage 1 will allow higher boost levels without throwing codes, but you still need to be careful. If you crank the boost too high and the computer can't supply enough fuel, you'll run the air/fue mixture too lean and could possibly cause MAJOR engine damage (BOOM!)
