Originally Posted by mino
i will pick up a pressure tester and let you know after i test - ( maybe the car was S-1 upgraded - i did buy it used )
If it is very easy to light up the tires and there is a sticker on the pcm that says "For Off Road Use Only" then it is S1. There is also a code that comes up when you do the key dance, but I don't remember what the code is.
