Originally Posted by quicksilverdon
You may get rattling with the ones you show - looks like their bases are smaller diameter than stock. If they are, go to home depot, etc, and get electrical grommets - get an assortment, but I think it's 3/8" you want, and fit them into the holes for the lock pins. If the rubber grabs too much, hit the pins with a shot of silicone spray.
Also - I found on both my '02 and '05 I had to use pliers to loosen the original lock pins - once started, I could unscrew the rest by hand.
I just did the same thing as you. I forgot about your post wen I came across some assorted grommets in my tool box and that's when the light came on.
Hey, I've read about this before!
Any way, I had to pull the OEM pin out and it boogered up the plastic vinyl just a tad. A hexagon base fitting through a round hole left 8 little marks on the plastic door panel. The grommet covers it up nicely, looks good and keeps it from rattling. I would rather have a small chrome retainer ring insert instead of the grommet but I'll take it as it is.
Thanks
Van
