Old 09 Nov 2007, 07:58 pm
CREWZIN CREWZIN is offline
Default Re: Cruiser 'stalls' when going thru 2500 rpm
Brenddie,
Sure sounds like the dreaded "intermittent electrical fault" which is probably about the hardest thing to find. The dealer should be able to hook up a scanner and let you drive around a couple days till the fault reappears. The dealers scanner has much more information than the code setting of the PT's computer and will pinpoint the exact fault when it actually happens.
