Thread: RE: Losing Air
  #16 (permalink)
Old 15 Nov 2007, 09:16 am
Default Re: Losing Air
Originally Posted by coolvirus View Post
Thanks crewzin. Pardon my ignorance but how would sanding the rim and the valve stem hole help in preventing air leaks? Is it to make a good seal between the tire and the rim?
Yes.
My daughter's 03 GT is having this problem - 3 wheels all lose air. I don't understand why it doesn't show up on leak test, except that the bead needs the weight of the vehicle to leak??
Anybody tried the goop (not fix-a-flat) that you put in tire? I saw it, but wanted to hear experience.
You take out valve stem, squirt this goop in, and it is supposed to seal punctures.
