Old 10 May 2003, 10:15 pm
Gear_Head Gear_Head is offline
Installed the HKS SSBOV today. Installed it in the same place as Chipmunk did, in Fact I used his pic & instructions to go by and it went on perfectly and works just great !!! Also installed the AutoMeter EGT Gauge (Pyrometer). I removed the cat and drilled the downpipe for the hollow bolt fitting. Installed the weld on inside the pipe & tightened & sealed. This was probably overkill, but I didn't want any posibility of exhaust leaks. It too is woking well. So, my turbo set up looks like this, TurboXs dual stage boost controller (1st stage set stock) second stage set to 12/13 steady spikes to 15 to 16 (momentary) max. I have the autostick and not the 5 speed, and a kickdown to 1st or 2nd gear will spin the tires. I have a tuned dual 2.5" exhaust system from Scottsdale muffler, and have low restriction intake w/K&N filter. I have ordered the 3 inch Turbo up intake from Jim Barnes in Fla. I am curious to see what difference this makes in performance. (no silencer in front of the turbo Intake). I plan on monitoring the performance for a while now.
[8)][8)][8)]
