Old 25 Nov 2007, 09:46 pm
sflamedic sflamedic is offline
Default Re: still having an engine hesitation...please help.
Okay talked to the misses and she says that the idle is normally at about 1000rpms and that when the car shutters that the idle drops to about 500rpms. Okay now about the IAC. When we got this car it was used with about 12000 miles on it. I noticed the first time that i changed the oil that a wire in the same location that you pointed out is about half way cut through. Its very close to the plug. Could that be the problem? If so is that plug fixable? Its to close to use a wire connector.
