Old 27 Nov 2007, 04:59 pm
Mean Green Mean Green is offline
Default Re: Are there any step by step instructions for mopar stage 2 wastegate and or dual s
Originally Posted by dmkolb View Post
I'm a new owner of a 2003 PT Cruiser GT. I'm automotive literate but not so much when it comes to forced induction. So I'm reading a ton of stuff about mopar stage 2 wastegate working on our PTs. I'm seeing posts about dual stage boost controls and of course Stage 1 kits.
So my question is will a mopar stage 2 wastegate do anything if installed by itself? If it will increase performance is it automatic or does it need to be dialed in (tuned). If I get a mopar stage 2 wastegate will the Stage 1 kit work with it? Then lastly do I need a dual stage boost controller with the first 2 add ons?
The car is a daily driver but I want a decent amount of power above what a stock PT GT has.
I did a search but nothing really answerers these questions and or explains once they are installed what needs to be adjusted and if anything needs to be monitored.
Before you raise the boost you need a boost gauge. After installing a boost gauge you can go with a Stage 2 wga by itself. It will work with Stage 1.
Check out the Mod Bible here for guidance.
PTCrew.com - Learn it or Burn it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
