Originally Posted by dmkolb
Ok I have a 2003 PT GT. I plan on getting the Mopar Stage 1 kit. But this isn't going to be enough for me. I'd also like a dual stage boost controller and I'll add a wastegate. I'll have a shop install the duel stage boost and wastegate and tune if for me just to be safe. So my main question is if I have the Stage 1 kit will this help the all around performance of the car vs the stock set up with a dual stage boost and wastegate setup?
You need to get the Mopar Stage 1 kit first, in your case 2003, the kit besides the PCM, you will get larger injectors, and that will give you a nice boost in power that you can build on, if you stay with the factory production PCM with the smaller injectors you will have less fuel and timing, also the stock PCM will give CEL light & codes if you boost past 15psi, where the Stage 1 over looks some of the sensors so you can play with more boost, 18 to 20 for the stock turbo, and a few other things.
