Thread: Stage I or not?
Old 29 Nov 2007, 05:56 pm
Mean Green Mean Green is offline
Default Re: Stage I or not?
Originally Posted by Dream4 View Post
Yes there is already a 2007 Stage 1 kit available, and it is worth a lot more hp than you think, even though the peak hp increase looks to not be that much, the increase in the mid range from 3000 to 5500 is 25 to 30 hp higher than stock, also if you look at the late 2005 and up Stage 1 install sheet, you will see that the hp ratings are measured at the wheels and not the crank like the factory hp ratings, the 2003 & 2004 Stage 1 kits were measured at the crank also, so there is still a good increase in the late stock 2005 & up 180 or 230hp at the crank engines to the 235hp rating at the wheels for the Mopar Stage 1 upgrade, this has been seen and proven on another forum, where several members with late 2005 and up Stage 1 cars were dyno tested at 230 to 240whp and 275 to 300ft-lbs of torque with the Mopar Stage 1 kit, and the upgraded plugs, wires and exhaust as recommended in the Stage 1 kit. I noticed a great improvement in engine and auto trans performance in my DC4 both on the street, and in my track times after adding the full Stage 1 upgrade 2.5 years ago.
Interesting. You must be talking about the Crew, but I don't remember that. I know they lied about the stock numbers for the SRT-4 from the beginning. My '05 Stage 2 install sheet still said 265 hp at the crank. I do know that is a lie, though, as my Aeroforce Interceptor scan gauge says with my S2 and TBE I'm running 336 hp at the crank which is around 280 whp. Yeah, it's a little rocket.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
