Old 30 Nov 2007, 06:05 pm
Cal Cruzer Cal Cruzer is offline
Default Re: 03 Pt Turbo upgrades
Listen to Mean Green. Don't waste you money on the "cold air" intake or jet chip. Stage 1 (the BEST mod), modded airbox and get some good piping to connect the airbox to the turbo will give you much better results. There are a couple hard pipe options available. It you look at the pipe connecting the airbox to the turbo you will see that is chokes down in the middle to act as a silencer in addition to the white "donut" in the airbox outlet. You can just pull the donut out of the airbox exit with no problems.
As for the Mopar bypass valve, yes it is mostly a noisemaker but I like hearing it so for a few bucks why not? Then you will want to start thinking about opening up the exhaust end of the equation...it goes on and on...welcome to the addiction.
