Re: Turbo Mods
Change your stock TTAB pipe,Uppipe, and lower pipe to hard ones, if you haven't already done that. Allows the boost to reach the engine sooner. The stock ones usually balloon and that causes a bit of a lag. That is unless you're at WOT, then it really doesn't matter too much. There's other things like replacing your plugs and wires and modifying the stock air box. Those are just some little things that when taken together make a bit of a difference.
