Old 10 Dec 2007, 07:29 pm
CREWZIN CREWZIN is offline
Default Re: Timing Belt Replacement?
Originally Posted by slartyblarfast View Post
Timing belt should be replaced at 120,000 miles. It is a non interference motor but I have seen them interfere!
Correct on both counts, but the school of thought with a lot of owners is 100,000 for the belt (to be on the safe side) and to go for a new water pump and belt tensioner while your at it as they both wear out and you/mechanic is in the area for the belt so might as well do the others.
