Old 15 Dec 2007, 09:52 pm
Cartman Cartman is offline
Default Re: Tranny Failed then Power Steering Switch?
DJmart- in theory you could test it with a DVOM. Problem is the car would have to be running and someone would have to turnt he steering lock to lock, while you were under the hood accessing the switch which is on the steering rack. it sounds like your switch isnt working, if the part is cheap enough it might be feasable to replace it. If your good with electrical, this might help you out.
OPERATION
The switch provides an input to the PCM during periods of high pump load and low engine RPM; such as during parking maneuvers.
When power steering pump pressure exceeds 2758 kPa (400 psi) , the switch is open. The PCM increases idle air flow through the IAC motor to prevent engine stalling. The PCM sends 12 volts through a resister to the sensor circuit to ground. When pump pressure is low, the switch is closed.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
