Old 15 Dec 2007, 10:46 pm
DJmart's Avatar
DJmart DJmart is offline
Send a message via AIM to DJmart
Default Re: Tranny Failed then Power Steering Switch?
Originally Posted by Cartman View Post
DJmart- in theory you could test it with a DVOM. Problem is the car would have to be running and someone would have to turnt he steering lock to lock, while you were under the hood accessing the switch which is on the steering rack. it sounds like your switch isnt working, if the part is cheap enough it might be feasable to replace it. If your good with electrical, this might help you out.
OPERATION
The switch provides an input to the PCM during periods of high pump load and low engine RPM; such as during parking maneuvers.
When power steering pump pressure exceeds 2758 kPa (400 psi) , the switch is open. The PCM increases idle air flow through the IAC motor to prevent engine stalling. The PCM sends 12 volts through a resister to the sensor circuit to ground. When pump pressure is low, the switch is closed.
sounds like something I can do!!! I am electrical handy
I'll work with my mechanic (we are good friends) and I will test the switch.
So I am guessing, no 12v reading... bad switch.?
