Old 16 Dec 2007, 05:56 pm
Nickatnite Nickatnite is offline
Default Instrument cluster lamps
So, I took apart everything necessary to replace the instrument lamps on my wifes 2002 Limited PT - not too much work (except the left dashboard end cover - more on that later) 3 were burned out, so I did them all. Anyway, I put it all back together, careful of course to make sure all the lamps lit before re-assembling. The highbeam indicator that did work berfore replacing the lamps, now doesn't work and everything else does. There were only 6 of the twist out lamp holders, not 7. Any ideas about what happened? Back to the left dashboard end cover. Anyone have any easy way to re-install it? Getting it under the door seal was a #*&*%^$## of a gun, I got it, but there must be an easier way than what I did . . .
Thanks,
Nickatnite
