Re: Instrument cluster lamps
there should have been 7 twist out sockets on the back of the cluster. two are int he center and the one on the bottom is the high beam indicator bulb. as for your end cap, did you remove the weatherstripping first or leave it in? its usually easier to pull the weatherstripping than fight it. and there is an order to removing all the items necessary to access the cluster....
removal 1. dash cap 2. steering column cover 3. end cap 4. bezel. install is reverse. going out of sequence causes difficulties. Hope this helps.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
