Old 17 Dec 2007, 08:27 pm
slartyblarfast slartyblarfast is offline
Default Re: couple questions
Vibrations in reverse are from the motor mounts. Slow speed vibration is either a bent rim or a tire that the cords have broken. It could also be axles... Normally that will show up under heavy acceleration. Also sounds like you need plugs and wires. As for the P/S.... More than likely not covered under powertrain warranty. Especailly since you are atleast second owner...
