Re: CV shaft after hub and bearing replacement?
did it act like this before you took it in for hub and bering replacement? usually when a CV joint goes out, you hear it clicking and clanking while turning well before any thumping is heard while normal driving. sometimes technicians get a little carried away and try to cut corners. perhaps they overextended the joint by letting it hang when they removed the knuckle. If the bad shaft was on the same side as the hub replacement, id say that it was damaged during the service and would argue that tot he death.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
